[原创] Maxim MAXREFDES82#智能力传感器参考设计
关键词:传感器 3D人机接口 智能传感器
时间:2016-06-07 11:28:13       作者:Maxim       来源:中电网
Maxim公司的MAXREFDES82#是新一代工业用智能力传感器,3D人接口输入,高精度重量度量,集成了低功耗24位模数转换器(ADC),主要用在3D人接口输入设备,电池为能源的仪表以及工业控制和测量.本文介绍了MAXREFDES82#主要特性,MAXREFDES82#参考设计框图,电路图和PCB元件布局图.
Maxim’s MAXREFDES82# features a next generation industrial, smart force sensor. Mounted on a quadrant of load cells channeled into a multi-channel, 24-bit analog-to-digital converter (ADC), MAXREFDES82# senses weight and center of mass for objects placed on the platform. The scale provides full-scale responses up to 780g. The user interface provides an active display of center of mass on the platform, as well as total measured weight. In addition to serving as a smart force sensor, the design works very well as a ruggedized touch interface with force sensing. The system consumes less than 50mA during normal operation and features a USB interface for quick evaluation and integration.
The board is designed in a compact form factor for rapid evaluation or installation. Refer to the Details tab for more information on the reference design. Design files and firmware can be downloaded from the Design Resources tab.
MAXREFDES82#主要特性:
3D Human Interface Input..
查看全文
