[原创] Cypress S6SAE101A太阳能供电IoT开发方案
关键词:物联网 IoT 电源管理 PMIC 无线传感器 S6SAE101A
时间:2016-05-23 10:09:21       作者:Cypress       来源:中电网
cypress公司的S6SAE101A是能量收获的电源管理集成电路(PMIC),集成了和太阳能电池串联连接的电路,输出功率控制电路,输出电容存储电路以及基本电池功率开关电路.超低电流250nA,起动功率仅为1.2 μW,主要用在非常小太阳能电池的能量收获电源系统,蓝牙智能传感器,无线HVAC传感器,无线照明控制,安全系统,智能家庭/建筑/工业无线传感器.本文介绍了S6SAE101A主要特性,架构框图,应用电路,以及太阳能供电物联网(IoT)开发套件S6SAE101A00SA1002主要特性,框图,能量收获主板电路图和电路图,BLE-USB桥电路图和材料清单.
The S6AE101A is a power management IC (PMIC) for energy harvesting that is built into circuits of solar cells connected in series,output power control circuits, output capacitor storage circuits, and power switching circuits of primary batteries. Super-low-poweroperation is possible using a consumption current of only 250 nA and startup power of only 1.2 μW. As a result, even slight amountsof power generation can be obtained from compact solar cells under low-brightness environments of approximately 100 lx. The
S6AE101A stores power generated by solar cells to an output capacitor using built-in switch control, and it turns on the powerswitching circuit while the capacitor voltage is within a preset maximum and minimum range for supplying energy to a load. If thepower generated from solar cells is not enough, energy can also be supplied in the same way as solar cells from connected primarybatteries for auxiliary power. Also, an over voltage protection (OVP) function is built into the input pins of the solar cells, and theopen voltage of solar cells is used by this IC to prevent an overvoltage state. The S6AE101A is provided as a battery-free wirelesssensor node solution that is operable by super-compact solar cells.
S6SAE101A主要特性:
Input power selection control: Solar cell or primary battery
Operated by solar cells without the need for primary batteries
Storage of energy from power supply to storage capacitors
Output power gating control, output voltage regulation
Operation input voltage range
Solar cell power : 2.0V to 5.5V
Primary battery power : 2.0V to 5.5V
Adjustable output voltage range : 1.1V to 5.2V
Low-consumption current : 250 nA
Minimum input power at startup : 1.2 μW
Input overvoltageprotection : 5.4V
Compact SON-10 package : 3 mm×3 mm
S6SAE101A应用:
Energy harvesting power system with a very small solar cell
Bluetooth® Smart sensor
Wireless HVAC sensor
Wireless lighting control
Security system
Smart home/Building/Industrial wireless sensor
图1.S6SAE101A简化框图
图2. S6SAE101A架构框图
图3. S6SAE101A应用电路图
The Solar-Powered IoT Device Kit provides an easy-to-use platform for the development of a solar-powered IoT device with BLE wireless connectivity. It includes the S6AE101A Energy Harvesting Power Management IC (PMIC) device, which is ideal for solar- or light-powered Energy Harvesting Systems (EHS) since it only consumes 250nA. The S6AE101A also supports a hybrid EHS that uses a solar cell Energy Harvesting Device (EHD) along with a coin cell battery, and an optional vibration EHD with external diode bridge. The output voltage from the S6AE101A is configurable from 1.1V to 5.2V, supporting a broad range of device components for an IoT device. Also included in the kit is Cypress’ EZ-BLE™ PRoC™ Module (CYBLE-022001-00), a fully integrated Bluetooth Low Energy (BLE) module solution that offers high flexibility for a wide variety of IoT device uses. A USB port is provided by Cypress’ USB-UART LP Bridge Controller device (CY7C65213).The Solar Powered IoT Device Kit provides everything needed to develop a light-powered sensor node that transmits sensor data using BLE:
Operates using light (>200 lux) energy harvested by the included solar cell
− Supports the use of a vibration Energy Harvesting Device with an external diode bridge (not included)
− Also supports the use of a coin cell battery (optional, not supplied)
Supports BLE communication with a PC through the provided BLE-USB Bridge that is pre-programmed with custom firmware for this kit
Includes firmware that supports the following applications:
− Bluetooth Low Energy (BLE) Beacon, transmitting data at 1.5 sec intervals with ambient light as low as 200 lx
− Wireless Sensor Node (WSN), transmitting data at 6 sec intervals with ambient light as low as 200 lx
Includes an expandable terminal on the Motherboard that can support the following:
− Reset button for EZ-BLE Module
− JTAG header to debug EZ-BLE Module
− Expandable sensor interface (I2C/UART/SPI/GPIO)
− DIP switch for future expansion (Not mounted)
− LEDs for USB power and status
Includes reference schematic, BOM list, and layout data for easy design
Uses the following Cypress Devices:
− S6AE101A ultra low power Energy Harvesting PMIC
− CYBLE-022001-00 EZ-BLE PRoC Module
− CY7C65213 USB-UART LP Bridge Controller
− MB39C022G LDO
物联网(IoT)开发套件S6SAE101A00SA1002包括:
Energy Harvesting Motherboard, which uses the following Cypress devices:
MB39C022G LDO
BLE-USB Bridge, which uses the following Cypress devices:
CY8C58LP PSoC 5LP
CYBL10162 PRoC BLE
Solar Module (Panasonic AM-1801)
USB Standard-A to Mini-B cable
Quick Start Guide
Two jumper wires, 220 μF Capacitor and 10Ω Resistor (to support example projects)
物联网(IoT)开发套件S6SAE101A00SA1002应用:
Battery-less wireless sensor node (WSN)
IoT device that monitors various sensors
BLE Beacon
Wearable device
Building Energy Management System (BEMS)
Home Energy Management System (HEMS)
Factory Energy Management System (FEMS)
Security system
图4.物联网(IoT)开发套件S6SAE101A00SA1002框图(1)
图5.物联网(IoT)开发套件S6SAE101A00SA1002外形图
图6.物联网(IoT)开发套件S6SAE101A00SA1002框图(2)
图7.物联网(IoT)开发套件S6SAE101A00SA1002能量收获主板外形图
图8.物联网(IoT)开发套件S6SAE101A00SA1002能量收获主板电路图(1)
图9.物联网(IoT)开发套件S6SAE101A00SA1002能量收获主板电路图(2)
物联网(IoT)开发套件S6SAE101A00SA1002能量收获主板材料清单:
图10.BLE-USB桥外形图
图11.BLE-USB桥电路图(1)
图12.BLE-USB桥电路图(2)
图13.BLE-USB桥电路图(3)
图14.BLE-USB桥电路图(4)
BLE-USB桥材料清单:
详情请见:
http://www.cypress.com/file/219311/download
http://www.cypress.com/file/187321/download
002-00297_00_V.pdf
002-08493_S6AE101A_Energy_Harvesting_PMIC_for_Wireless_Sensor_Node.pdf
002-08495_S6AE101A_Energy_Harvesting_PMIC_for_Wireless_Sensor_Node_Chinese.pdf
