低功率 LED 照明趋势解决方案-第四部分
关键词:A19、E14/17、E26/27灯泡 单级PFC反激式拓扑 单级初级侧调节(PSR)反激式解决方案 PFC PSR反激式拓扑
时间:2016-02-26 17:16:18       来源:中电网
A19, E14 / 17, E26 / 27 bulb LED Driver Design
LED lighting trend in our blog series, we discussed the MR11 / 16 LED driver design problems. Now, let’s look at A19, E14 / 17, E26 / 27 bulb LED driver designs.
Some bulb type is called “screw caps” and “candle light.” Most with CFL or LED incandescent replacement, has won the majority of application requirements.
A19, E14 / 17, E26 / 27 screw bulb structure
Input voltage directly from the AC power socket type: E14 / 17 (Candle), A19 / E26 / 27 (screw type) (for candle lamp, rated 1~5W; to replace incandescent lamps, rated power 4~17W.) dimensions shown in Figure 1 and Figure 2.
Figure 1. Example candle lamps ((L: 99 毫米, D: 26 毫米, E: 17 mm) of
Figure 2. Example Edison light bulb (L: 105 毫米, D: 55 毫米, B: 26 mm) of
A19, E14 / 17, E26 / 27 screw bulb LED Driver Design Challenge
查看全文
