[原创] ST STM32F401高性能32位MCU开发方案
关键词:ARM Cortex-M4 MCU 马达驱动 工业控制 医疗电子 家庭音响设备 STM32F401
时间:2016-01-21 13:25:15       作者:ST        来源:中电网
ST公司的STM32F401XB/STM32F401XC是基于ARM® Cortex® -M4 32位RISC核的高性别能MCU,工作频率高达84MHz,内核局有浮点单元(FPU),支持所有ARM单精度数据指令和数据类型,还能执行DSP指令和存储器保护单元(MPU)指令,多达256KB闪存和64KB SRAM,主要用在马达驱动和应用控制,医疗设备,工业应用如PLC,逆变器和电路中断器,打印机和扫描仪,告警系统,视频连接和HVAC,家庭音响设备和移动手机传感器集线器.本文介绍了STM32F401主要特性,框图,STM32 Nucleo-64开发板NUCLEO-F401RE主要特性,框图,电路图和材料清单,元器件布局图.
The STM32F401XB/STM32F401XC devices are based on the high-performanceARM® Cortex® -M4 32-bit RISC core operating at a frequency of up to 84 MHz. Its Cortex®-M4 core features a Floating point unit (FPU) single precision which supports all ARM singleprecisiondata-processing instructions and data types. It also implements a full set of DSPinstructions and a memory protection unit (MPU) which enhances application security.
The STM32F401xB/STM32F401xC incorporate high-speed embedded memories (up to 256 Kbytes of Flash memory, up to 64 Kbytes of SRAM), and an extensive range of enhanced I/Os and peripherals connected to two APB buses, two AHB buses and a 32-bit multi-AHB bus matrix.
查看全文
