[原创] Cypress S6E1A1系列32位MCU评估方案
关键词:ARM Cortex-M0+ MCU 消费类电子 家用电器 S6E1A1
时间:2015-11-20 11:21:20       作者:Cypress       来源:中电网
Cypress公司的S6E1A1系列是高度集成32位MCU,采用ARM Cortex-M0+处理器,集成了多达88kB片上闪存和SRAM,以及如各种计时器,ADC,通信接口(UART, CSIO, I2C, LIN)等外设功能,CPU工作频率40MHz,主要用在低功耗和低成本的应用.本文介绍了S6E1A1主要特性,框图,以及FM0-V48-S6E1A1评估板特性,框图,电路图和PCB设计图.
These MCUs are designed for applications that require advanced, high-speed computing performance such as general-purpose inverters, servomotors, "industry 4.0" factory automation, PLCs and other industrial equipment, as well as medical and surveillance products, and inverter-based home appliances such as washing machines and air conditioners.
The S6E1A1 Series is a series of highly integrated 32-bit microcontrollers designed for embeddedcontrollers aiming at low power consumption and low cost.
This series has the ARM Cortex-M0+ Processor with on-chip Flash memory and SRAM, and consists ofperipheral functions such as various timers, ADCs and communication interfaces (UART, CSIO, I2C, LIN).
S6E1A1主要特性:
32-bit ARM Cortex-M0+ Core
 Processor version: r0p1
 Maximum operating frequency: 40 MHz..
查看全文
