[原创] Renesas RX64M 32位MCU开发方案
关键词:MCU 工业控制 网络通信 仪太网 RX64M
时间:2015-03-17 15:57:10       作者:Renesas       来源:中电网
Renesas公司的RX64M是工作频率高达120MHz的32位RX MCU,采用功能强大的RXv2核,具有片上FPU,240DMIPS,多达4MB闪存,51KB SRAM,包括IEEE 1588兼容的以太网MAC,全速USB 2.0,SD主接口,四个SPI,CAN,12位ADC,RTC,加密,用于音频的串行接口和CMOS照相机接口在内的各种通信接口.工作电压2.7到3.6V,主要用在工业设备,网络设备和需要实时性能和大容量存储器的其它应用.本文介绍了RX64M主要特性,功能框图, RX64M RX64M入门套件主要特性, HMI扩展板框图,RX64M CPU板和HMI扩展板系统配置图以及HMI扩展板R0K50564MB001BR电路图和RX64M CPU板电路图.
The RX64M Group 32-bit microcontrollers are capable of operating at up to 120 MHz. The RX64M employs the powerfully evolved RXv2 core, which is backward compatible with the RX core employed in existing RX products. The RXv2 core enables 1.35 times the Coremark/MHz performance and a 40% reduction in power consumption compared to existing RX products, and even higher code efficiency, allowing the realization of high-speed, low consumption systems.
查看全文
