[原创] Maxim MAX32600超低功耗MCU健康产品开发方案
关键词:ARM Cortex-M3 MCU 健康传感器 模拟前端(AFE) 穿戴医疗电子 血糖仪 脉搏血氧计
时间:2015-01-04 09:44:53       作者:Maxim       来源:中电网
Maxim公司的MAX32600是集成了健康传感器模拟前端(AFE)和先进的硬件安全的超低功耗RM Cortex-M3 32位MCU,工作频率高达24MHz,包括256KB闪存,32KB SRAM,2KB指令缓存以及高性能模拟外设.主要用在穿戴医疗电子,血糖仪,脉搏血氧计和皮肤电反应测量.本文介绍了MAX32600主要特性和优势以及其它特性,功能框图,以及MAX32600评估板主要特性,框图,电路图和材料清单.
The MAX32600 microcontroller is based on the industry-standard ARM® Cortex®-M3 32-bit RISC CPU operating at up to 24MHz. It includes 256KB of flash memory, 32KB of SRAM, a 2KB instruction cache, and integrated high-performance analog peripherals.
The MAX32600 comes in 192-ball, 12mm x 12mm CTBGA and 120-ball, 7mm x 7mm CTBGAand 108-ball WLP packages.
MAX32600主要特性和优势:
Integrated AFE Enables Precision Wellness Measurements with Minimal Discretes 16-Bit ADC with Input Mux and PGA Up to 500ksps Conversion Rate PGA with Gain of 1, 2, 4, and 8 and Bypass Mode Differential 8:1 or Single-Ended 16:1 Input Mux Internal Mux Inputs for Measuring VDDA3
Internal or External Voltage Reference Programmable Buffers for ADC and DACs
Two 12-Bit DACs and Two 8-Bit DACs
Four Operational Amplifiers
Four Low-Power Comparators
Four Uncommitted SPST Analog Switches
Four Ground Switches
Up to Eight 100mA LED Driver Pairs (Sink) ..
查看全文
