关键词:OFDM 动力线通信(PLC) 动力线网络 智能电网 智能电表 PRIME ST7590
时间:2014-10-24 11:21:13 作者:ST 来源:中电网
ST公司的ST7590是首个窄带OFDM动力线通信系统极芯片(SoC),具有嵌入了OFDM调制的高性能DSP引擎,可编比特率高达128kps,器件集成了多种外设和128位AES加密硬件区块,模拟前端和动力线驱动器,主要用在PRIME兼容的智能电表和智能电网.本文介绍了ST7590主要特性,框图,两个应用案例,以及评估板EVALST7590T-2主要特性,框图,电路图和材料清单.
ST7590 is the first complete Narrowband OFDM power line communication system-on-chip made using a multi-power technology with state of the art VLSI CMOS lithography. The ST7590 is based on dual core architecture to assure outstanding communication performance with a very high level of flexibility and programmability for either open standard or fully customized implementations.
ST7590主要特性:
■ Fully integrated narrow-band power line networking system-on-chip
■ High performing DSP engine with embedded turn-key firmware for Orthogonal frequency division multiplexing (OFDM) modulation, featuring:
– 96 sub-carriers in CENELEC A band
– BDPSK, QDPSK, 8DPSK programmable modulations
– Programmable bit rate up to 128 kbps
– Convolutional coding and Viterbi decoding
– Signal to noise ratio and channel quality estimation
– Full PRIME compliant PHY
■ On chip peripherals:
– Host controller UART/SPI interface
– I2C/SPI external data memory interface..
分享到:
