[原创] Atmel ATmega256RFR2系统级芯片无线参考设计
关键词:AVR MCU 无线MCU ZigBee IEEE 802.15.4 IPv6/6LoWPAN WirelessHART RF4CE
时间:2014-10-14 10:57:04       作者:Atmel       来源:中电网
Atmel公司的ATmega256RFR2是基于AVR增强RISC架构的低功耗CMOS 8位MCU,集成了用于2.4GHz ISM频段的高数据速率收发器,具有135条功能强大的指令,具有256KB/128KB/64KB在系统自编程的闪存,8kB/4kB/2kB EEPROM及32KB/16KB/8KB SRAM,主要用在ZigBee® / IEEE 802.15.4-2011/2006/2003™全功能设备,带MCU的通用2.4GHz ISM收发器以及RF4CE, SP100, WirelessHART™, ISM应用和IPv6 / 6LoWPAN.本文介绍了ATmega256RFR2主要特性,框图, 基本应用电图及材料清单, 扩展特性应用电图以及参考设计RCB256RFR2主要特性,框图,电路图和材料清单以及PCB元件布局图.
The ATmega256/128/64RFR2 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture combined with a high data rate transceiver for the 2.4 GHz ISM band.
By executing powerful instructions in a single clock cycle, the device achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
The radio transceiver provides high data rates from 250 kb/s up to 2 Mb/s, frame handling, outstanding receiver sensitivity and high transmit output power enabling a very robust wireless communication.
ATmega256RFR2主要特性:
• Network support by hardware assisted Multiple PAN Address Filtering
• Advanced Hardware assisted Reduced Power Consumption..
查看全文
