ADI AD9652 310MSPS取样16位ADC评估方案
关键词:ADC 模数转换器 无线通信 雷达 3G/4G 测试测量 智能天线系统
时间:2014-08-13 11:38:05       作者:ADI       来源:中电网
ADI公司的AD9652是双路16位模数转换器(ADC),取样速率高达310MSPS,输入频率高达450MHz是有极好的动态范围,噪音−157.6 dBFS, SFDR超过85dBFS,通路隔离90dB,工作电压3.3V和1.8V,总功耗2.16W,主要用在军用雷达和通信,多模式数字接收器(3G或4G), 测试测量和智能天线系统.本文介绍了AD9652产品亮点和主要特性,功能框图,以及AD9652评估板主要特性,电路图和材料清单.
The AD9652 is a dual, 16-bit analog-to-digital converter (ADC) with sampling speeds of up to 310 MSPS. It is designed to support demanding, high speed signal processing applications that require exceptional dynamic range over a wide input frequency range (up to 465 MHz). Its exceptional low noise floor of −157.6 dBFS and large signal spurious-free dynamic range (SFDR) performance (exceeding 85 dBFS, typical) allows low level signals to be resolved in the presence of large signals.
The dual ADC cores feature a multistage, pipelined architecture with integrated output error correction logic. A high performance on-chip buffer and internal voltage reference simplify the inter-face to external driving circuitry while preserving the exceptional performance of the ADC.
查看全文
