PowerInt LYT2004E 8.6W LED驱动电源参考设计(DER424)
关键词:电源管理 LED驱动器 开关电源
时间:2014-06-18 11:06:04       作者:PowerInt       来源:中电网
PowerInt公司的LYTSwitch-2系列产品是不需要光耦和次级控制电路的低功率恒流(CC) LED驱动器,包括了750V高压开关MOSFET,创新的ON/OFF控制状态机,用于自偏压的高压开关电流源,降低EMI的频率抖动器,逐个周期的限流和滞后的热关断等功能,无负载功耗低于30mW.主要用于LED灯,顶灯, 照明器具,镇流器和T8管灯.本文介绍了LYTSwitch-2系列产品亮点,功能框图,典型应用电路,以及采用LYT2004E的通用输入22V-48V/180mA绝缘的反激LED驱动器参考设计424主要特性和技术指标,电路图,材料清单和PCB元件布局图.
The LYTSwitch-2 family of ICs dramatically simplifies low power CC LED drivers by eliminating the optocoupler and secondary control circuitry. The family introduces a revolutionary control technique to provide accurate output current regulation, compensating for transformer and external component variations, and device parameter tolerances as well as input voltage variations.
The device incorporates a high-voltage switching MOSFET, a novel ON/OFF control state machine, a high-voltage switched current source for self-biasing, frequency jitter to reduce EMI, cycle-by-cycle current limit and hysteretic thermal shutdown circuitry into a monolithic IC. This high level of integration enables highly cost-effective designs with very few external components, reducing solution cost and driver size.
查看全文
