Freescale MMPF0200 12路可配置电源管理解决方案
关键词:Freescale MMPF0200 12路可配置电源管理 DC/DC转换器 智能能源
时间:2014-04-18 09:16:29       作者:Freescale       来源:中电网
Freescale公司的MMPF0200是12路可配置电源管理集成电路(PMIC),具有高度可编程/配置的架构,包括四个降压转换器,一个升压转换器,六个线性稳压器,RTC电源和纽扣电池充电器,特别适合于i.MX系列如i.MX 6SoloLite, i.MX 6Solo和i.MX 6DualLite供电,主要应用在平板电脑,IPTV,工业控制,医疗监视,家庭自动化/告警/能量管理.本文介绍了PF0200主要特性, 简化内部框图,功能框图,典型应用电路图,以及评估板KITPF0200EPEVBE主要特性,测试建立图,电路图,材料清单和PCB元件布局图.
The PF0200 Power Management Integrated Circuit (PMIC) provides a highly programmable/ configurable architecture, with fully integrated power devices and minimal external components. With up to four buck converters, one boost regulator, six linear regulators, RTC supply, and coin-cell charger, the PF0200 can provide power for a complete system, including applications processors, memory, and system peripherals, in a wide range of applications. With on-chip One Time Programmable (OTP) memory, the PF0200 is available in pre-programmed standard versions, or non-programmed to support custom programming. The PF0200 is especially suited to the i.MX 6SoloLite, i.MX 6Solo and i.MX 6DualLite versions of the i.MX 6 family of devices and is supported by full system level reference designs, and pre-programmed versions of the device. This device is powered by SMARTMOS technology.
PF0200主要特性:
查看全文
