Infineon XMC4500 32位MCU工业应用开发方案
关键词:工业控制 工业连接 电源转换
时间:2014-03-18 10:56:22       作者:Infineon       来源:中电网
Infineon公司的XMC4500是XMC4000系列产品中一员,是高性能和节能的基于ARM Cortex-M4 CPU的32位MCU,具有DSP/MAC指令,浮点单元,存储器保护单元和嵌套矢量中断控制器,适合用于工业连接,工业控制,电源转换以及传感控制.本文介绍了XMC4500主要特性, 系统框图,以及CPU_45A-V3应用开发板主要特性,框图,电路图和材料清单.
The XMC4500 devices are members of the XMC4000 Family of microcontrollers based on the ARM Cortex-M4 processor core. The XMC4000 is a family of high performance and energy efficient microcontrollers optimized for Industrial Connectivity, Industrial Control, Power Conversion, Sense & Control.
XMC4500主要特性:
CPU Subsystem
• CPU Core
– High Performance 32-bit ARM Cortex-M4 CPU
– 16-bit and 32-bit Thumb2 instruction set
– DSP/MAC instructions
– System timer (SysTick) for Operating System support
• Floating Point Unit
• Memory Protection Unit
• Nested Vectored Interrupt Controller
• Two General Purpose DMA with up-to 12 channels
• Event Request Unit (ERU) for programmable processing of external and internal service requests
• Flexible CRC Engine (FCE) for multiple bit error detection
On-Chip Memories
• 16 KB on-chip boot ROM
• 64 KB on-chip high-speed program memory..
查看全文
