ST 无刷电机解决方案
关键词:无刷电机 3相永磁无刷电动机驱动器 STEVAL-IHM040V1
时间:2013-09-03 14:13:05       作者:ST       来源:中电网
Keywords: BLDC,3-phase permanent magnet brushless motor driver ,STEVAL-IHM040V1
基本特点:
The STEVAL-IHM040V1 is a 3-phase permanent  magnet brushless motor driver designed to drive a motor using either the six step or field oriented  control (FOC) commutation technique. The board  can operate from an AC mains of either 115 or  230 VAC nominal at 50/60 Hz, or from a DC input voltage between 150 and 350 VDC. The board can supply a continuous output current of 0.5 ARMS to the motor.
Extended AC input mains range: 115 or 230
VAC nominal at 50/60 Hz, or DC input voltage
Output current: 0.5 ARMS to the motor
Power stage: 3-phase inverter bridge
implemented using the STGIPN3H60 SLLIMMnano intelligent power module
RoHS compliant
方案描述:
查看全文
