ADI ADN2812 评估板参考设计方案
关键词:ADI ADN2812评估板参考设计方案
时间:2012-10-26 14:41:32       作者:ADI       来源:中电网
ADN2812是ADI公司生产的一款具有量化接收机功能,信号电平检测、时钟和数据恢复功能,连续数据率从12.3Mb/s到2.7Gb/s。ADN2812芯片在没有外部基准时钟或编程的情况下,自动锁存所有数据速率。满足所有光纤网络抖动,包括抖动转移、抖动生成和抖动公差。本文主要介绍ADN2812的主要特性、方框图及其应用。同时介绍EVAL-ADN2812EB评估板、电路图、材料清单和PCB Layout图。
The ADN2812 provides the receiver functions of quantization, signal level detect, and clock and data recovery for continuous data rates from 12.3 Mb/s to 2.7 Gb/s. The ADN2812 auto-matically locks to all data rates without the need for an external reference clock or programming. All SONET jitter requirements are met, including jitter transfer, jitter generation, and jitter tolerance. All specifications are quoted for −40℃ to +85℃ ambient temperature, unless otherwise noted.
This device, together with a PIN diode and a TIA preamplifier, can implement a highly integrated, low cost, low power fiber optic receiver.
The receiver front end, loss of signal (LOS) detector circuit indicates when the input signal level has fallen below a user-adjustable threshold. The LOS detect circuit has hysteresis to prevent chatter at the output.
The ADN2812 is available in a compact 5 mm × 5 mm 32-lead lead frame chip scale package (LFCSP).
查看全文
