Avnet DVI I/O FMC模块数字视频接口解决方案
关键词:工业控制 数字视频接口
时间:2012-09-10 10:51:19       作者:Avnet       来源:DVI
Avnet公司的DVI I/O FMC模块提供数字视频接口,直接连接到Xilinx® Spartan®-6或 Virtex®-6 FMC使能的基板,数字DVI视频源为模块提供视频内容,而模块提供数字DVI和DisplayPort输出,用来显示FPGA驱动的视频内容.本文介绍了DVI I/O FMC模块主要特性,框图,DVI输入和输出框图,DisplayPort输出框图,以及模块电路图和材料清单(BOM).
This FMC module provides a direct interface to digital video to Xilinx® Spartan®-6 or Virtex®-6 FMC-enabled baseboards. A digital DVI video source can provide video content to the module. The module also provides digital DVI and DisplayPort outputs to display FPGA driven video content.
The DVI I/O FMC Module is not a stand-alone module, but rather a plug-in module designed to interface with FMC compatible baseboards. In that role, the DVI I/O FMC Module provides a number of video interfaces to its host via a LPC FMC connector.
The DVI I/O FMC Module is a low pin count (LPC) FMC module containing interfaces intended for video processing. This module contains no processing intelligence and requires that it be plugged into a compatible baseboard for power, control and data processing.
DVI I/O FMC模块主要特性:
Video Input
— DVI input interface (HDMI connector)
Video Output
查看全文
