Renesas R8A66597 USB连接解决方案
关键词:消费类电子 DVD STB 音频设备
时间:2012-09-06 09:31:54       作者:Renesas       来源:R8A66597
Renesas公司的R8A66597 通用串行总线(USB)控制器,具有16位CPU总线接口,配备了USB主功能和可用于OTG的外设功能.器件内置了USB收发器,和USB 2.0所有传输类型兼容,内部缓冲存储器是8.5KB.低功耗工作,内核电压1.5V,主要用于导航系统,DVD,STB,音频设备,打印机,外部存储设备和其它配备了USB的设备.本文介绍了R8A66597主要特性,引脚功能框图以及评估板R0K866597D020BR主要特性,电路图,材料清单和PCB元件布局图.
The R8A66597 is a Universal Serial Bus (USB) Controller equipped with USB Host functions and Peripheral functions applicable for On-The-Go. When selecting the Host Controller function, it has two USB ports available for Hi-Speed, Full-Speed, and Low-Speed transfer compliant with USB Specification Revision 2.0. When selecting the Peripheral Controller function, it has one USB port available for Hi-Speed and Full-Speed transfer compliant with USB Specification Revision 2.0.
This controller has a built-in USB transceiver and is compatible with all the transfer types defined in USB Specification Revision 2.0.
查看全文
