ADI ADuC7060模拟微控制器开发方案
关键词:工业控制 过程控制 传感器 数据采集
时间:2012-08-20 10:52:31       作者:ADI       来源:ADuC7060
ADI公司的ADuC7060/ADuC7061是低功耗全集成的8 kSPS,24位数据采集系统,在单芯片上集成高性能多通道Σ-Δ型模数转换器(ADC),16位/32位ARM7TDMI® MCU和Flash/EE存储器,包括有4个定时器,高级矢量中断控制器,工作电压2.375 V至2.625 V,工作温度范围为−40℃至+125℃,主要用在工业自动化和过程控制,智能精密检测系统和4 mA至20 mA环路智能传感器。本文介绍了ADuC706x系列主要特性,功能框图,模拟框图以及ADuC7060评估板主要特性,电路图,材料清单和PCB元件布局图.
The ADuC706x series are fully integrated, 8 kSPS, 24-bit data acqui-sition systems incorporating high performance multichannel sigma-delta (Σ-Δ) analog-to-digital converters (ADCs), 16-bit/ 32-bit ARM7TDMI®MCU, and Flash/EE memory on a single chip.
The ADCs consist of a primary ADC with two differential pairs or four single-ended channels and an auxiliary ADC with up to seven channels. The ADCs operate in single-ended or differential input mode. A single-channel buffered voltage output DAC is available on chip. The DAC output range is programmable to one of four voltage ranges.
查看全文
