On Semi NCP1075 15W低功耗离线开关电源解决方案
关键词:电源管理 AC/DC转换器 开关电源
时间:2012-08-10 09:34:42       作者:On Semi       来源:NCP1075
On Semi公司的NCP1072/NCP1075集成了700V MOSFET的固定频率电流模式控制器,包括软起动,频率抖动,短路保护,最大峰值电流设定点,斜率补偿,跳频模式,动态自供电源,无负载输入功耗小于 50 mW,主要用于辅助电源,待机电源,白色家电,智能电表.本文介绍了NCP1072/NCP1075主要特性,方框图,12V/0.85A通用输入电源电路图和15W开关电源评估板电路图,材料清单.
The NCP1072/NCP1075 products integrate a fixed frequency current mode controller with a 700 V MOSFET. Available in a PDIP−7 or SOT−223 package, the NCP1072/5 offer a high level of integration, including soft−start, frequency−jittering, short−circuit protection, skip−cycle, a maximum peak current set point, ramp compensation, and a Dynamic Self−Supply (eliminating the need for an auxiliary winding).
Unlike other monolithic solutions, the NCP1072/5 is quiet by nature: during nominal load operation, the part switches at one of the available frequencies (65, 100 or 130 kHz). When the output power demand diminishes, the IC automatically enters frequency foldback mode and provides excellent efficiency at light loads. When the power demand reduces further, it enters into a skip mode to reduce the standby consumption down to a no load condition.
查看全文
