Holtek HT7945平板电脑WLED背光驱动方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2012-07-17 10:26:15       作者:Holtek       来源:HT7945
盛群半导体(Holtek)公司的HT7945是用于笔记型计算机及平板计算机显示器WLED背光的驱动器,各WLED之间的电流控制精度在±1.5%之内,输入电压范围为4.5~26V,提供8信道LED电流接口,工作频率可选择为500kHz或1MHz,内置的功率NMOS的额定最大电流为2.2A,提供WLED串开路及断路保护。其它的保护机制有过电压保护、限流保护、过热保护及低电压锁定等.本文介绍HT7945主要特性,方框图,典型应用电路图和PCB布局图.
The HT7945 is a high efficiency DC-DC controller which can drive multiple WLEDs connected in a series/parallel configuration. The device has a wide input voltage, ranging from 4.5V to 26V, and an adjustable 15mA to 30mA WLED current, setup using an external resistor. In total, the device can support up to 88 WLED.
In addition, eight current sink regulators provide ±1.5% high precision current matching between strings. The brightness can be adjusted by an external PWM signal with frequency up to 20kHz. Once an open/short string is detected, that string is disabled while the other strings continue to operate normally.
Other protection includes soft-start, under voltage lockout, programmable over voltage protection, switch current limit and thermal shutdown.
The HT7945 is supplied in a QFN 24 pin 4x4 tiny footprint package type
HT7945主要特性:
• Max input voltage: 26V
• Integrated Power Mosfet
查看全文
