Microchip MRF24WB0MA 2.4GHz Wi-Fi解决方案
关键词:通信技术 无线通信 Wi-Fi IEEE Std. 802.11b
时间:2012-07-11 09:38:54       作者:Microchip       来源:MRF24WB0MA
Microchip公司的MRF24WB0MA/MRF24WB0MB是低功耗2.4 GHz, IEEE Std. 802.11b兼容的RF收发器模块,表面安装模块(尺寸32mmx31mm),具有所有的RF元件如晶振,旁路和片压无源元件,MAC,基带,RF和功率放大器,以及支持AES和TKIP (WEP, WPA, WPA2安全)的硬件.数据速率领1和2Mbps,IEEE Std. 802.11b/g/n兼容,工作电压2.7V–3.6V, ISM频段2.400–2.484 GHz,DSSS调制,1Mbps的灵敏度-91dBm,输出功率+10dBm可控,主要用在智能电表,消费类电子,遥控设备管理和零售业.本文介绍了MRF24WB0MA主要特性,方框图,应用电路图以及Wi-Fi通用演示板主要特性,电路图和元件布局图及主要元件.
The MRF24WB0MA and MRF24WB0MB are low-power,2.4 GHz, IEEE Std. 802.11-compliant, surface mount modules with all associated RF components – crystal oscillator, bypass and bias passives with integrated MAC, baseband, RF and power amplifier, and built-in hardware support for AES, and TKIP (WEP, WPA, WPA2 security). The integrated module design frees the designer from RF and antenna design tasks and regulatory compliance testing, ultimately providing quicker time to market.
The MRF24WB0MA module is approved for use with the integrated PCB meander antenna.
The MRF24WB0MB comes with an ultra miniature coaxial connector (U.FL) and is approved for use with a list of pre-certified antennas.
查看全文
