TI LMP91050非分散红外(NDIR)检测AFE解决方案
关键词:工业控制 传感器 建筑物监测 酒精检测 工业安全
时间:2012-03-09 14:04:35       作者:TI       来源:LMP91050
TI 公司的LMP91050是可编程的传感器模拟前端(AFE),最适合用于温度传感器和非分散红外(NDIR)检测应用。器件提供了传感器和MCU间完整的通路,可编程增益从167V/V到7986V/V,工作电压2.7V 到5.5V,(0.1 到10 Hz)噪音为 0.1μVRMS,最大增益漂移为100 ppm/℃,相位漂移为500ns,主要用在NDIR检测,通风控制,建筑物监测,汽车电子的CO2舱控制和酒精检测,GHG和氟利昂检测平台。本文介绍了LMP91050主要指标和特性,方框图,典型NDIR传感应用电路图以及SPIO-4精密信号通路控制器板主要特性,方框图,电路图和PCB元件布局图。
Configurable AFE for Nondispersive Infrared (NDIR) Sensing Applications
The LMP91050 is a programmable integrated Sensor Analog Front End (AFE) optimized for thermopile sensors, as typically used in NDIR applications. It provides a complete signal path solution between a sensor and microcontroller that generates an output voltage proportional to the thermopile voltage. The LMP91050 s programmability enables it to support multiple thermopile sensors with a single design as opposed to the multiple discrete solutions.
查看全文
