Atmel AT86RF232 2.4GHz ZigBee解决方案
关键词:通信技术 无线通信 ZigBee IEEE 802.15.4 6LoWPAN
时间:2011-10-26 11:27:06       作者:Atmel       来源:AT86RF232
Atmel公司的AT86RF232是用于ZigBee, IEEE 802.15.4, 6LoWPAN, RF4CE以及ISM的2.4GHz低功耗收发器,是真正的SPI到天线解决方案.所有的RF元件,除了天线,晶体和去偶电容都集成在芯片中.接收器灵敏度为-100dBm,可编程输出功率从-17dBm到+3dBm,超低工作电压1.8V-3.6V(内部有稳压器),睡眠模式电流为0.4uA,最大发射功率时的功耗为13.8mA,AES 128位硬件加速器.本文介绍了AT86RF232主要特性,方框图, 接收器和发送器方框图, 基本应用电路图及其材料清单, 扩展特性应用电路图和REB232ED-EK评估板主要特性,电路图,材料清单和PCB布局图.
The Atmel AT86RF232 is a low-power 2.4GHz radio transceiver designed for consumer ZigBee/IEEE 802.15.4, RF4CE, 6LoWPAN, and 2.4GHz ISM band applications. The radio transceiver is a true SPI-to-antenna solution. All RF-critical components except the antenna, crystal and de-coupling capacitors are integrated on-chip. Therefore, the AT86RF232 is particularly suitable for applications like:
 2.4GHz IEEE 802.15.4 and ZigBee systems
 RF4CE systems
 6LoWPAN systems
 Wireless sensor networks
 Residential and commercial automation
 Health care
 Consumer electronics
 PC peripherals
The AT86RF232 can be operated by using an external microcontroller like Atmel AVR® microcontrollers.
AT86RF232主要特性:
查看全文
