Semtech SC5010超薄笔记本相移式8通道白光LED背光驱动方案
关键词:电源管理 DC/DC转换器 LED驱动器
时间:2011-09-13 09:45:57       作者:Semtech       来源:SC5010
Semtech(升特)公司的 SC5010是超薄笔记本面板用的相移式8通道白光LED背光驱动器,采用创新的PWM相移调光控制法,可使用1mm高的2.2μH微型电感,用于高效超薄的4mm厚度显示器.SC5010提供精确的背光色温以及全屏一致的亮度,通道间的电流匹配度为+/-1%,精度为+/-1.5%。它有完备的保护功能,包括LED开路保护和可编程的LED短路保护、可调过压保护(OVP),以及过热保护;另外还有欠压锁定(UVLO)关断功能。器件输入电4.5V至27V;输出电压最高达50V, 最高效率达92%,最多可驱动112只白光LED,主要用在超薄笔记本电脑,UMPC,LCD监视器和平板电脑.本文介绍了SC5010主要特性,方框图,LED PWM调光控制框图,详细应用电路以及SEPIC配置图,高输出电压应用电路图.
The SC5010 is an 8-channel high-precision, high-effi ciency step-up (Boost) LED driver for backlight applications. It features wide input voltage range (4.5V to 27V) , fl exible output configuration, wide analog and PWM dimming range, phase shifting and fading. It also features video signal synchronization (VSYNC), I2C interface, and numerous protection features. An optional disconnect p-MOSFET provides true load disconnection and inrush current limiting.
The boost controller, with programmable switching frequency from 200kHz to 2.2MHz, maximizes effi ciency by dynamically minimizing the output voltage while maintaining LED string current accuracy. It provides excellent line and load response with no external compensation components.
查看全文
