Cypress CY8CLEDAC02 12W调光LED驱动参考设计方案
关键词:电源管理 LED驱动器 AC/DC转换器
时间:2011-08-25 13:32:41       作者:Cypress       来源:CY8CLEDAC02
Cypress 公司的CY8CLEDAC02是高性能离线LED驱动器,AC离线输入从80V到277VAC,输出功率高达25W,调光范围从2%到100%,智能墙壁调光器检测,主要用在可调光的离线LED驱动器,可调光的LED替代灯以及可调光的LED光源。本文介绍了CY8CLEDAC02主要特性,逻辑方框图,简化的应用电路图以及12W 220VAC输入调光LED驱动器参考设计指标,电路图,变压器指标与电路图以及材料清单,PCB元件布局图。
The CY8CLEDAC02 is a high performance offline LED driver, designed to interface directly with most conventional phase cut based wall dimmers. The device uses proprietary digital control technology to provide automatic detection of dimmer type (leading or trailing edge). It automatically generates dimming signals for LED loads and has the ability to dim down to 2 percent. It modulates LED brightness using a linear dimming scheme and switches to a pulse width modulation (PWM) based dimming scheme for output current levels lower than 20 percent of the full load current. In PWM mode optimized dimming frequencies in the range of 900 Hz result in zero visible flicker.At the heart of a CY8CLEDAC02 based system is the chopping circuit which provides the load necessary to enable correct wall dimmer operation. It also improves PF when there is no dimmer on the line.
查看全文
