ZMDI ZSSC3170汽车传感器信号调理方案
关键词:汽车电子 LIN PWM 工业控制 传感器信号调理
时间:2011-05-09 11:47:54       作者:ZMDI        来源:ZSSC3170
ZMDI公司的ZSSC3170是集成了LIN和PWM接口的汽车传感器信号调理器,最大模拟增益420,并具有扩展的失调补偿.器件和LIN指标1.3 / 2.0 / 2.1兼容,数据转换速率高达430Hz,电源电压7-18V,ADC分辨率13-14位,输出分辨率达12位,睡眠模式的电流消耗小于100uA.本文介绍了ZSSC3170主要特性, 方框图和多种应用电路.
ZSSC3170: Automotive Sensor Signal Conditioner with LIN and PWM Interface
The ZSSC3170 is a CMOS integrated circuit for highly accurate amplification and sensor specific correction of bridge sensor signals. Featuring a maximum analog gain of 420, as well as extended offset compensation capabilities, the ZSSC3170 is adjustable to nearly all resistive bridge sensor types.
Digital compensation of offset, sensitivity, temperature drift, and nonlinearity is accomplished via a 16-bit RISC microcontroller. Conditioning coefficients are stored in an EEPROM certified for automotive applications.
Measured values are provided by one of the digital LIN or PWM interfaces. Each interface can support end-of-line calibration using the sensor output. Noise sensitivity is greatly reduced because the calibration equipment and the ZSSC3170 are mated digitally.
查看全文
