Supertex HV9971高精度LED电流控制解决方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2011-03-15 10:57:54       作者:Supertex       来源:HV9971
Supertex公司的 HV9971是不连续导通模式(DCM)反激LED驱动器,可以工作满负荷100kHz开关频率,通用80-264VAC输入电压,±3% LED电流精度,自适应于外部元件误差和寄生参数,输出开路和短路保护,主要用在低功耗照明。本文介绍了HV9971主要特性,功能方框图和典型应用电路图。
The HV9971 is a primary-side control IC for driving a discontinuous conduction mode (DCM) flyback LED driver. The IC is optimized for operation at a constant full-load switching frequency of 100kHz and the universal input AC voltage range of 80-264VAC. It maintains 3% variation of the LED current setting, and features tight line and load regulation. The proprietary primary-side output current control employed in the HV9971 makes the output current setting insensitive to most component tolerances and parasitics without use of an opto-feedback.
The HV9971 LED driver is fully protected against output open and short circuit conditions and input under-voltage. It also offers a logic input for dimming the LED light output by means of pulse-width modulation of the output current.
The HV9971 is ideally suited for driving high-brightness LEDs in low-power lighting fixtures such as incandescent bulb retrofits.
HV9971主要特性:
►► Programmable true constant current operation
查看全文
