Allegro A4934三相风扇控制解决方案
关键词:工业控制 马达控制 风扇控制
时间:2011-03-02 09:35:02       作者:Allegro       来源:A4934
Allegro 公司的A4934是三相马达驱动器,它采用BEMF检测,从而在风扇应用是不需要霍尔传感器.PWM输入用来控制马达的转速,具有软开关以降低可听噪音,FG速度输出,低功耗待机模式和锁定检测.本文介绍了A4934主要特性和优势,功能方框图,典型应用电路及相应的元件值.
The A4934 three-phase motor driver incorporates BEMF sensing to eliminate the requirement for Hall sensors in fan applications.
A pulse wave modulated (PWM) input is provided to control motor speed, allowing system cost savings by eliminating external variable power supply. PWM input can also be used
as an on/off switch to disable motor operation and place the IC into a low power standby mode.
The A4934 soft switching settings are designed for lower inductance or lower speed motors. For higher inductance or higher speed motors consider using the pin-compatible A4941.
The A4934 is provided in a 16-pin TSSOP package (suffix LP) with an exposed thermal pad. It is lead (Pb) free, with 100% matte tin leadframe plating.
A4934主要特性和优势:
• Sensorless (no Hall sensors required)
• Soft switching for reduced audible noise
• Minimal external components
• PWM speed input
• FG speed output
• Low power standby mode
• Lock detection..
查看全文
