Freescale MMA845X三轴14位数字加速度计解决方案
关键词:工业控制 传感器 加速度计
时间:2011-02-17 10:20:13       作者:Freescale       来源:MMA845X
Freescale公司的MMA8451Q是14位/8位智能低功耗三轴数字加速度计,工作电压1.95V-3.6V,接口电压1.6V-3.6V,动态可选择满刻度为±2g/±4g/±8g,输出数据速率(ODR)从1.56 Hz 到800 Hz, 噪音为99 ug/√Hz,14位和8位数字输出,I2C数字输出接口,主要用在电子罗盘,静态方向检测,笔记电脑,电子阅读器,实时方向检测(如3D定位反馈)和实时行为分析(如计步器).本文介绍了MMA8451Q主要特性, 方框图, 应用框图以及MMA845X 传感器加速度计板LFSTBEB845X电路图和元件布局图.
3-Axis, 14-bit/8-bit Digital Accelerometer
The MMA8451Q is a smart low-power, three-axis, capacitive micromachined accelerometer with 14 bits of resolution. This accelerometer is packed with embedded functions with flexible user programmable options, configurable to two interrupt pins. Embedded interrupt functions allow for overall power savings relieving the host processor from continuously polling data. There is access to both low pass filtered data as well as high pass filtered data, which minimizes the data analysis required for jolt detection and faster transitions. The device can be configured to generate inertial wake-up interrupt signals from any combination of the configurable embedded functions allowing the MMA8451Q to monitor events and remain in a low power mode during periods of inactivity. The MMA8451Q is available in a 3 mm x 3 mm x 1 mm QFN package.
MMA8451Q主要特性:
查看全文
