Cypress CY3664-enCoRe III开发系统解决方案
关键词:通信技术 无线通信 enCoRe III PSoC
时间:2011-02-09 10:46:07       作者:Cypress       来源:CY3664
Cypress公司的CY7C603xx系列是低压enCoRe III PSoC器件,采用功能强大的哈佛架构,M8C处理器的速度高达12MHz,工作电压2.4V-3.6V,具有可配置的外设如8位定时器,计数器和PWM,全双工主或从SPI,10位ADC,8位SAR ADC和比较器,闪存程序存储器,SRAM数据存储器和可配置的I/O口,主要用在无线鼠标,无线游戏手柄, PlayStation® 2有线游戏手柄以及各种低压8位MCU应用.本文介绍了CY7C603xx 主要特性,方框图, 数字系统方框图和模拟系统方框图,以及enCoRe(TM) III开发系统电路图和材料清单(BOM).
The enCoRe III Low Voltage (enCoRe III LV) CY7C603xx device is based on the flexible PSoC® architecture. This supports a simple set of peripherals that can be configured to match the needs of each application. Additionally, a fast CPU, Flash program memory, SRAM data memory, and configurable IO are included in a range of convenient pinouts.
CY7C603xx 主要特性:
■ Powerful Harvard Architecture Processor
❐ M8C Processor Speeds to 12 MHz
❐ Low Power at High Speed
❐ 2.4V to 3.6V Operating Voltage
❐ Operating Voltages down to 1.0V using On-Chip Switch Mode Pump (SMP)
❐ Commercial Temperature Range: 0℃ to +70℃
■ Configurable Peripherals
❐ 8-Bit Timers, Counters, and PWM
❐ Full Duplex Master or Slave SPI
❐ 10-Bit ADC
查看全文
