Austriamicrosystems AS5013霍尔传感器解决方案
关键词:工业控制 霍尔传感器 传感器
时间:2010-12-16 09:40:15       作者:Austriamicrosystems       来源:AS5013
Austriamicrosystems公司的AS5013是完整的低功耗霍尔传感器,适用于智能导航的主要应用. AS5013工作电压2.7V-3.6V,外设电压可低到1.7V,有两种工作模式:空闲模式和低功耗模式, 空闲模式的功耗小于3uA,具有两种中断模式,横向磁场运动半径高达2mm,可用在手机,MP3播放器,PDA,GPS接收器和游戏机等.本文介绍了AS5013主要特性和优势, 方框图, 和MCU的电连接框图以及用于小型游戏操纵杆的布局案例.
AS5013 :Low Power Integrated Hall IC for Human Interface Applications
The AS5013 is a complete Hall Sensor IC for smart navigation key applications to meet the low power requirements and host SW integration challenges for products such as cell phones and smart handheld devices.
Due to the on chip processing engine, system designers are not tasked with integrating complex SW algorithms on their host processor thus leading to rapid development cycles.
The AS5013 single-chip IC includes 5 integrated Hall sensing elements for detecting up to ±2mm lateral displacement, high resolution ADC, XY coordinate and motion detection engine combined with a smart power management controller.
The X and Y positions coordinates and magnetic field information for each Hall sensor element is transmitted over a 2-wire I²C compliant interface to the host processor.
查看全文
