Linear LTM4628双路8A DC-DC稳压电源方案
关键词:电源管理 DC/DC转换器 DC/DC μModule稳压器
时间:2010-12-13 10:51:39       作者:Linear       来源:LTM4628
Linear公司的LTM4628是双路8A 或单路DC/DC μModule稳压器,包括有开关控制器,功率FET,电感以及所有的支持元件.输入电压从4.5V到 26.5V,两输出的电压从0.6V 到 5.5V,由外接电阻设定,直流输出总误差为±1.5%,主要用在通信和网络设备,存储和ATCA卡以及工业设备.本文介绍了LTM4628主要特性, 简化方框图以及各种应用电路图.
LTM4628: Dual 8A or Single 16A DC/DC μModule Regulator
The LTM4628 is a complete dual 8A output switching mode DC/DC power supply and can be easily configured to provide a single 2-phase 16A output. Included in the package are the switching controller, power FETs, inductor, and all supporting components. Operating from an input voltage range of 4.5V to 26.5V, the LTM4628 supports two outputs each with an output voltage range of 0.6V to 5.5V, set by a single external resistor. Its high efficiency design delivers 8A continuous current for each output. Only a few input and output capacitors are needed.
The device supports frequency synchronization, multiphase operation, Burst Mode operation and output voltage tracking for supply rail sequencing. It has an onboard temperature diode for device temperature monitoring.
High switching frequency and a current mode architecture enable a very fast transient response to line and load changes without sacrificing stability.
查看全文
