ADI ADuM347x四路带PWM控制和变压器驱动数字隔离方案
关键词:工业控制 过程控制 传感器
时间:2010-10-27 13:37:25       作者:ADI       来源:ADuM347x
ADI公司的ADuM347x是四路带PWM控制和变压器驱动数字隔离器,采用ADI的iCoupler技术,器件的DC/DC转换器提供高达2W的输出,5.0V或3.3V输入输出电压从3.3V到24V, 200 kHz 到1 MHz可调频率,主要用在RS-232/RS-422/RS-485收发器,工业现存总线隔离,绝缘传感器接口和过程控制等.本文介绍了ADuM347x主要特性,功能方框图,I/O通路框图以及单电源与正和不稳压负电源的应用电路图,所用变压器参考设计.
The ADuM347xdevices are quad-channel, digital isolators with an integrated PWM controller and transformer driver for an isolated dc-to-dc converter. Based on the Analog Devices, Inc., iCoupler technology, the dc-to-dc converter provides up to 2 W of regulated, isolated power at 3.3 V to 24 V from a 5.0 V input supply or from a 3.3 V supply. This eliminates the need for a separate, isolated dc-to-dc converter in 2 W isolated designs.
The iCoupler chip-scale transformer technology is used to isolate the logic signals, and the integrated transformer driver with isolated secondary side control provides higher efficiency for the isolated dc-to-dc converter. The result is a small form factor, total isolation solution.
The ADuM347x isolators provide four independent isolation channels in a variety of channel configurations and data rates.
ADuM347x主要特性:
Isolated PWM Controller
Integrated transformer driver
查看全文
