NXP LPC2930高速USB-OTG接口方案
关键词:计算机与外设 USB OTG
时间:2010-05-17 11:41:32       作者:NXP       来源:中电网
NXP公司的LPC2930是集成了ARM968E-S CPU核和两个TCM区块的MCU,工作频率高达125MHz,并具有全速USB 2.0 Host/OTG/Device控制器,CAN和LIN,56 kB SRAM,外接存储器接口,三个10位ADC和多种串行接口,可广泛应用在消费电子,工业和通信市场。本文介绍了LPC2930主要特性和优势,整体方框图和各种功能的方框图,包括时钟区框图,调制和取样控制子系统(MSCSS)方框图,ADC方框图,PWM方框图,PCRSS方框图,CGU0和CGU1方框图,时钟发生架构图和PLL方框图以及自供电USB接口框图与USB OTG端口配置图。
The LPC2930 combine an ARM968E-S CPU core with two integrated TCM blocks operating at frequencies of up to 125 MHz, Full-speed USB 2.0 Host/OTG/Device controller, CAN and LIN, 56 kB SRAM, external memory interface, three 10-bit ADCs, and multiple serial and parallel interfaces in a single chip targeted at consumer, industrial, and communication markets. To optimize system power consumption, the LPC2930 has a very flexible Clock Generation Unit (CGU) that provides dynamic clock gating and scaling.
LPC2930主要特性和优势:
ARM968E-S processor running at frequencies of up to 125 MHz maximum.
Multilayer AHB system bus at 125 MHz with four separate layers.
On-chip memory:
Two Tightly Coupled Memories (TCM), 32 kB Instruction TCM (ITCM), 32 kB Data TCM (DTCM).
Two separate internal Static RAM (SRAM) instances; 32 kB SRAM and 16 kB SRAM.
查看全文
