ST STi7106新一代多用途HD STB解决方案
关键词:消费类电子 HB STB
时间:2010-03-23 13:54:00       来源:ST, , ,
ST公司的STi7106是新一代多用途HD STB解决方案,采用先进的高清(HD)译码(H264/VC-1/MPEG2/AVS),满足STB和蓝光DVD播放器的制造需求,和DVB, ISMA, ATIS-IIF, SCTE, DirecTV, ATSC, ARIB, CEA, ITU, OpenCable, MSTV以及BD规范兼容.STi7106在单片内集成了主流传输解调技术,应用CPU,A/V译码,视频处理,图像和显示器,先进的安全性,STB接口,音频/视频DAC, HDMI, 双e-SATA 端口, 双USB端口,双以太网控制器(1x GbE)以及MMC/SD/SDIO卡控制器.本文介绍STi7106主要特性和优势,方框图以及典型应用框图,包括有线以太网或Wi-Fi 连接的IP客户端HD STB方框图,混合DTT/IP HD STB方框图,带MoCA的双调谐DVB-C/IP HD DVR STB方框图,带DOCSIS多调谐DVB-C/IP HD DVR STB方框图和双调谐DVB-S2/IP HD DVR STB方框图.
The STi7106 is targeted at the latest operator and CE manufacturer requirements for STBs and Blu-ray DVD players, which utilize advanced HD decoding(H264/VC-1/MPEG2/AVS), and which conform to DVB, ISMA, ATIS-IIF, SCTE, DirecTV, ATSC, ARIB, CEA, ITU, OpenCable, MSTV, and BD specifications.
The STi7106 provides a solution for operators to specify a range of cost-efficient, high performance HD STBs including cost-efficient zappers, IP clients, interactive STBs, DVR standalone and DVR server/home network capable STBs, and with content delivery possible using broadcast or broadband networks, or both (hybrid STBs).
查看全文
