Freescale MC9S08LL16自动调温参考设计
关键词:电源管理 其它
时间:2010-01-08 12:27:00       来源:Freescale
Freescale公司的MC9S08LL16自动调温参考设计具有8位HCS08中央处理器器件(CPU),片上存储器,省电模式,时钟源选项,系统保护,开发支持,外设,输入/输出,以及封装选项等性能。本文主要介绍了MC9S08LL16特性和方框图、自动调温方框图、低端和高端调温图,配置图等。
Thermostat Reference Design
MC9S08LL16 Series Covers: MC9S08LL16 and MC9S08LL8
Features
• 8-Bit HCS08 Central Processor Unit (CPU)
– Up to 20-MHz CPU at 3.6V to 1.8V across temperature range of -40°C to 85°C
– HC08 instruction set with added BGND instruction
– Support for up to 32 interrupt/reset sources
• On-Chip Memory
– Dual Array FLASH read/program/erase over full operating voltage and temperature
Random-access memory (RAM)
– Security circuitry to prevent unauthorized access to RAM and FLASH contents
• Power-Saving Modes
– Two low power stop modes
– Reduced power wait mode
– Low power run and wait modes allow peripherals to run while voltage regulator is in standby
– Peripheral clock gating register can disable clocks to unused modules, thereby reducing currents.
– Very low power external oscillator that can be used in stop2 or stop3 modes to provide accurate clock source to real time counter
查看全文
