Anadigics AWT6241 TD-SCDMA手机线性功率放大方案
关键词:通信技术 3G手机 TD-SCDMA UMTS WCDMA
时间:2009-12-01 10:56:00       来源:Anadigics
Anadigics 公司的AWT6241 是HELP3TM UMTS/TD-SCDMA线性功率放大模块,采用InGAP HBT技术,单模式控制输入,工作频率在1880-1920MHz和2010-2025MHz.工作电压从3.2V到4.2V, POUT = +27.5 dBm的效率为28%,主要用在TD-SCDMA 1.8/2.0频段以及 UMTS/WCDMA IMT 2.1 GHz的无线手机和数据设备.本文介绍AWT6241主要特性,方框图和典型应用电路.
AWT6241: HELP3TM UMTS/TD-SCDMA Linear Power Amplifier Module
The AWT6241 HELP3TM PA is a next generation product for UMTS handsets. This PA incorporates ANADIGICS’ HELP3TM technology to provide low power consumption without the need for an external voltage regulator or DC/DC Converter. The AWT6241 is manufactured on an advanced InGaP HBT MMIC technology offering state-of-the-art reliability, temperature stability, and ruggedness. There are two operating modes for optimum efficiency at high and medium/low power output levels with a single mode input. A shutdown mode with low leakagecurrent increases handset talk and standby-time. The self-contained 3 mm x 3 mm x 1 mm surface mount package incorporates matching networks optimized for output power, efficiency, and linearity in a 50 Ω system.
AWT6241主要特性:
• InGAP HBT Technology
• Single mode control input
查看全文
