Freescle MC56F8006 BLDC马达控制方案
关键词:工业控制 马达控制 BLDC PMSM
时间:2009-11-11 10:13:00       来源:Freescle
Freescle 公司的MC56F8006//MC56F8002是数字信号控制器(DSC),在单片上集成了DSP的处理功能和微控制器的功能,以及各种外设,以创建非常高性能比的解决方案. MC56F8006//MC56F8002包括多达16KB的程序闪存,2KB 数据/程序RAM,32MHz核频率的性能高达32MIPS,主要应用于工业控制,家用电器,智能传感器,防火和安防系数,开关电源和电源管理,电表,马达控制以及仪器仪表等.本文介绍MC56F8006//MC56F8002主要特性,方框图,内核方框图, 外设子系统方框图, 控制器子板电路图和材料清单.
MC56F8006/MC56F8002 Digital Signal Controller
The 56F8006/56F8002 is a member of the 56800E core-based family of digital signal controllers (DSCs). It combines, on a single chip, the processing power of a DSP and the functionality of a microcontroller with a flexible set of peripherals to create an extremely cost-effective solution.
Because of its low cost, configuration flexibility, and compact program code, the 56F8006/56F8002 is well-suited for many applications. The 56F8006/56F8002 includes many peripherals that are especially useful for cost-sensitive applications, including:
• Industrial control
• Home appliances
• Smart sensors
• Fire and security systems
• Switched-mode power supply and power management
• Power metering
• Motor control (ACIM, BLDC, PMSM, SR, and stepper)
查看全文
