NXP TDA18218HN DVB-T电视硅调谐方案
关键词:消费类电子 HDTV STB DVB-T TV
时间:2009-08-17 13:56:00       来源:NXP
NXP 公司的TDA18218HN是 DVB-T电视用的硅调谐器IC,集成了全部的调谐功能,包括选择性和提供低IF输出信号. TDA18218HN采用综合的IF滤波器,支持6MHz,7MHz以及8MHz的信道带宽,单电源3.3V工作,I2C总线接口.外接元件仅为16MHz的晶振,用作时钟发生器,主要用在DVB-T机顶盒(STB)和TV接收器.本文介绍了TDA18218HN的主要特性,方框图以及典型应用框图.
The TDA18218HN is a Silicon Tuner IC designed for digital terrestrial (DVB-T) TV reception. The TDA18218HN integrates the overall tuning function, including selectivity and provides a low-IF output signal.
The TDA18218HN uses integrated IF filters to support 6 MHz, 7 MHz or 8 MHz channel bandwidths. The TDA18218HN requires only one single 16 MHz crystal for clock generation. A clock signal is available on crystal oscillator output pins (XTO_P / XTO_N) to synchronize the channel decoder.
The TDA18218HN is a low cost Silicon Tuner targeting digital terrestrial applications. The TDA18218HN matches the performance of the conventional can tuners. Additionally, the following benefits can be stated:
• Easy on-board integration
• Drastically reduces:
– the size of the tuner function
– the power consumption
TDA18218HN主要特性:
Fully integrated IF selectivity; eliminating the need for external SAW filters
查看全文
