Microchip PIC24H 16位MCU入门开发方案
关键词:工业控制 传感器信号调理 MCU
时间:2009-07-16 16:38:00       来源:Microchip
Microchip公司的PIC24H系列16位MCU包括有The PIC24HJ32GP302/304, PIC24HJ64GPX02/X04以及PIC24HJ128GPX02/X04,采用16位带有增强指令集和寻址模式的改进型哈佛架构,CPU有24位指令,程序计数器(PC)是23位宽,地址高达4Mx24位,广泛用于传感器信号捕获和处理,语音译码和播放以及OLED显示器的控制.本文介绍了PIC24H系列16位MCU的主要特性,方框图和CPU内核方框图以及PIC24H MPLAB® 入门开发套件的方框图,调试方框图和所用元件表,详细电路图包括处理器电路图, 加速度计电路图, 扬声器电路图, 差分放大器和低通滤波器电路图, OLED显示器电路图,开发测试点电路图和USB接口/目标电源开关与调试输入和控制电路图.
PIC24H High-Performance, 16-bit Microcontrollers
The PIC24HJ32GP302/304, PIC24HJ64GPX02/X04, and PIC24HJ128GPX02/X04 CPU module has a 16-bit (data) modified Harvard architecture with an enhanced instruction set and addressing modes. The CPU has a 24-bit instruction word with a variable length opcode field. The Program Counter (PC) is 23 bits wide and addresses up to 4M x 24 bits of user program memory space. The actual amount of program memory implemented varies by device. A single-cycle instruction prefetch mechanism is used to help maintain throughput and provides predictable execution. All instructions execute in a single cycle,..
查看全文
